jbozz601
SOLD!!
Alright i got this from the website, I have one but i bought it because i thought i was going to use it. need to sell it because i have stuff to take care of before i start buying just stuff that i dont need at the time. you can read the specs about it here. i paid $190 to my door
picture at bottom is what you get. i can send you pictures of it from my phone.
text or call me at 601-616-1969 anytime.
im asking $175 shipped
The HD HERO 960 features the same professional grade 960p, 720p and 480p (WVGA) video & 5MP timelapse photo modes, and incredible sound recording system as its big brother, the original HD HERO camera.
Record up to 2.5 hours on a single charge and up to 9 hours total on a 32GB SD card (not included).
Missing from the HD HERO 960 are 720p @ 60fps, 1080p video, and the HERO BUS expansion port in the rear of the camera that will let you take advantage of GoPro’s forthcoming BacPac accessories – LCD screen & Battery Extension – both important features for filmmaking hobbyists & professional videographers that are compatible with the original HD HERO camera.
What’s Included:
Camera Optics
What’s Included:
- 1 HD HERO 960 camera
- 1 Rechargeable 1100 mAh Lithium-Ion Battery
- 1 Waterproof Quick-Release Housing (180′ / 60m)
- 1 Curved, 3M™ Adhesive Mount
- 1 Flat, 3M™ Adhesive Mount
- 1 Helmet Front Mount
- 1 Headlamp-Style Head Strap
- 1 Quick-Release Buckle
- 1 USB Cable
- 1 Component Video Cable (HDTV)
- 1 Composite Video Cable + Audio Out Cable
- Warranty: One Year
Camera Optics
- Lens Type: Fixed Focus (2ft/.6m – ∞), glass
- Aperture: f/2.8 (high performance in low-light situations)
- Angle of View: 170º ultra wide angle in WVGA, 720p, or 960p mode
- HD Video Resolution Modes: (subject to change, pending final firmware release)
- 960p = 1280×960 pixels (4:3), 30 fps, 12 Mbit/s data rate
- 720p = 1280×720 pixels (16:9), 30 fps, 8 Mbit/s data rate
- WVGA = 848×480 pixels (16:9), 60 fps, 8 Mbit/s data rate
- Sensor Type: 1/2.5″ HD CMOS, 2.2µm-sized pixels
- Light Sensitivity: Super low-light sensitivity (>1.4 V/lux-sec)
- Video Format: H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
- Exposure Control: Auto with user selectable center weighted average and spot metering settings
- White Balance: Auto
- Microphone: Built-in, mono with AGC (automatic gain control)
- Audio Format: 48 kHz, AAC audio compression
- Resolution: 5 megapixel
- Capture Modes: Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
- Memory: SD card (SDHC), up to 32GB capacity (not included)
- Average recording times (using 32GB SD card):
- 960p (30 fps): 5h 26m
- 720p (30 fps): 8h 09m
- WVGA (60 fps): 8h 09m
- PC Connection: USB 2.0 (data connection and battery charging)
- HDTV Out: HD NTSC & PAL (component cable incl.)
- Audio Out: Combo 2.5mm jack with stereo audio and composite video out
- PC Compatibility: Windows® Vista or Windows® 7; Mac OS® X 10.4.11 and later
- Battery Type: Rechargeable 1100 mAh lithium-ion
- Battery Life: Approx. 2.5 hrs
- Charging: via USB to computer or optional power adapter
- Charge Time: 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer’s USB port
- Depth Rating: Up to 180 feet / 60 meters
- Construction: Polycarbonate and stainless steel
- Hardware: Stainless steel
- Dimensions (H x W x D): 1.6” x 2.4” x 1.2” (42mm x 60mm x 30mm)
- Weight: 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
- Additional Rechargable 1100 mAh Lithium-Ion Battery
- Full Line of Mounting Accessories
