Guys that have changed gears themselves
KonaGT
Can anyone tell me what the pinion bearing preload is supposed to be with a new bearing? My inch lb torque wrench is 3/8" drive, what did you guys use to adapt from 3/8 to the pinion nut?
I want to use a solid spacer instead of a crush sleeve, what do you torque the pinion nut to with the spacer?
