I'll provide all details and let you guys decide what is pertinent.
2006 Mustang GT 22,000 miles - almost all highway, so suspension is in great shape - no worn parts. Stock 18" tires, stock suspension - not lowered.
Took the car in for oil/tire rotation/alignment. No problems at all before the visit - alignment was just preventative maintenance.
Afterwards, it didn't want to track straight - constantly fighting to keep it from drifting left and right. Took it back to recheck the alignment - they said everything was good. So, I checked the tire pressure (Accu-gauge dial type gauge) and it read 24 all around! So I filled to 32. thought that would do it.
It actually seemed worse - felt like driving in heavy wind with no wind. Took it back again - again everything in spec (this time I got the printout), BUT, they said tire pressure was at 45! Long story short, my "Accu"gauge was off by about 12 PSI.
However, I'm still having issues. Car tracks straight and steady now, but I'm getting significant tramlining (tendency for the car to pull in the direction of a longitudinal rut or crease in the road). Never did that before. Tire pressure is definitely correct now. No bumpsteer at all.
Here's the alignment results:
Camber: Right -.06 Left -1.0 Total -.03 Factory Range: -.08 to +.08
Caster: Right +6.5 Left +7.0 Total +.05 Factory Range: -.08 to +.08
Toe: Right +.05 Left +.08 Total +.12 Factory Range: -.10 to +.30
So, questions:
- Is it possible for the alignment to be incorrect even if the print out says all is within spec?
- Could the tire rotation have brought on the tramlining (i.e the tread wear on the front wheels is different than the ones that were there before the rotation)?
- Is tramlining usually due to tires or suspension/alignment?
- If it is in alignment, could they have messed with something else that could cause tramlining?
- What do you suggest I do next?
Thanks in advance.
So, questions:
Thanks in advance.
