Has anyone ran the MT Drags 29.5?
169stang
Steeler Nation
Holeshot wheels will run you just shy of $1300. Bogarts will cost you just over $1600.
29.5" tires will somewhat fit. They will get sliced a bit as they will hit the fender on the front side. Justin Burcham's surely did (ET Streets). We were at an event once and we were trying to "make" room so they didn't rub any longer. It put little slices in his tires. You could see it happening as he went down the track. It was more on the top end of the track then down low. The tire balloned with speed. The DR's may not ballon as much as the ET Streets.
I also have a set of the 325's and you definitely have to "massage" the shock mount. If you turn too hard w/little air in the tire, they'll slightly rub the lower control arm too....occasionally.
