I've had mine wrapped for 2 years. Neither the turbor nor the stainless steel downpipe has rusted. Turbo and pipe are WAY too close to the fan to not wrap it. As a matter of fact, even with moving the radiator forward I still had to dremel the fan a bit. The difference in underhood temp with and without is tremendous. If you don't wrap the turbo hot side, make absolutely sure that your hood insulation is in good shape. You will end up with a nice blister on the top of the hood. Don't bother with the turbo hot feed. That is actually a waste. I run the stock exhaust manifolds on mine, with all the porting I could do.
