BLACK-MACHINE
living my 2nd child hood
- Joined
- Jul 18, 2013
- Posts
- 3,255
- Reaction score
- 3
can the element pad be replaced without tearing the foam padding all to hell. my seat takes forever to heat up.
thanks.
thanks.
I plan to get some aftermarket ones as soon as she come back out of hibernation. Since I have a 'vert I'm hoping that heated seats can get me a few more top down days.
so the more i dug into my issue of the seat not heating up in what i thought was a timely fashion, ( passenger seat is almost instant) i found out there is a relay\control module under each seat.
i gave mine a tap with a screw driver and my seat heated with in minutes. called ford.
$230.00... its almost spring...... right.
What type of relay? That sounds like a stuck contact on the other side of a relay coil. Can you swap the relay out? When the seat wasn't heating, did the button indicate the heater was on (I assume their is a light on the button)?
