*JZ*
Hellion has officially released its single turbo system for the 2011 Mustang GT. The completely stainless steel turbo system installs easily with no modifications and is sent 100 percent complete—including ECU re-calibration. The system can be supplied with a 64mm up to a 78 mm turbo. A 6 psi base setting will make over 600 hp, and the system is capable of 950hp—try that with a twin-screw! Call Hellion today for maximum performance.System Includes:
- Turbonetics billet 64 mm turbo
- All stainless steel construction (lifetime warranty)
- Turbosmart Wastegate
- Hand held tuner with program
- 52 lb injectors
System Options
Ball bearing upgrade for Hellion/Turbonetics
76mm Turbonetics Turbo
76mm Precision Turbo HPS
76mm Precision HPA (ball bearing)
Turbosmart boost TEE manual boost controller
Turbosmart E boost 2 boost controller
Turbosmart E boost Street boost controller
AEM wide band O2 kit
- 52 lb injectors
System Options
