A new problem sort of arose today on my way home. I was stopped on a exit ramp in traffic and started to let the clutch pedal up and a rattle noise came from the engine area it wouldn't stop. I originally thought it was because I was starting in third gear or something. So I kept pulling it out of gear and putting it in first gear, no change. I began tapping the gas pedal to see if the noise would change with the engine rpm and it faded away. It only started to happened again on another slight steep grade of road but the noise was not constant as the last time.
Any thoughts on what this could be?
I was thinking it could be the thow out bearing. I could hear it start to make the rattle sound, sometimes when I don't push enough on the gas pedal when releasing the clutch pedal.
