Help, car won't start ... ok it's only my wife's car not the mustang
Itchy
Maryland
Ok my wife's car won't start. I turn the key and there is one single click. We were able to jump it, so I thought that meant I could rule out a bad starter.
I decided to just replace the battery with the most expensive battery on the planet, because GM picked an odd size and non of the major generic autoparts stores claimed to carry a normal battery for the car.
It still won't start? What the deuce?
GIG4FUN
Rock 'n' Roll Moderator
Iowa
even though we were able to jumpstart it?
I'll bet when you jumped it you gave it a lot more amps. Electrical stuff really performs differently at various stages of heat/wear/voltage/amps etc.
Solenoid or the actual starter (armature/brushes could be worn) etc.
Itchy
Maryland
What a pain in the arse that engine compartment is. I don't know if I can even get to the starter without takeing out a few things. The air box and inlet tube are going to have to come out, and then the exhaust manifold still gets in the way.
I guess that's why V8s are not meant to be FWD
GIG4FUN
Iowa
well with all due respect... It's your wifes car.... AND for gosh sake use the warranty!
Itchy
Maryland
it only had a 36000 mile one, and we are at 41000. So that's not an option, smartass, :)
And yeah I know it's my wife's car which is why it has become my problem
GIG4FUN
Iowa
all a surprise....:shock:
GIG4FUN
Iowa
I'm gunna feel like shit if it ain't the solenoid or starter.... maybe check a bit more or get more opinions here. It sounds like too much effort for a guess.
Itchy
Maryland
ok so we jumped it again, and drove it around and then turned off and it started up again. I let it sit for awhile and it started up again. Does that make sense to anyone?
1Fast05Turbo
Flying Low
Valrico, FL
Makes sense? Well yeah...it's a GM...:samuri:
LOL...J/K. It doesn't make any sense...
Hawgman
THE fucking bad guy
Texas
You've obviously never removed the starter from your Mustang!
Speaking of Mustangs.... once you get a handle on the issue I am going to relocate this thread to the Pit since it is not "Mustang Tech" related
Itchy
Maryland
Sorry I wasn't sure where to post it but, I figured it would get answered the quickest here.
Hawgman
THE fucking bad guy
Texas
And I agree. The tech section would definitely get more visibility. No worries.
cekim
Large Member
Earth
Just to recap:
old battery = click - no start
jump = worked
new battery (first time) = click - no start
new battery (after some charging) = works?
If so, then the new battery needed a charge...
When the battery is low, you will here the solenoid click but it has has insufficient power to turn the engine so nothing else happens. Even a new battery needs to charge - it will leak out its charge sitting on the shelf...
