Due to what I believe was a bad oil filter I may have driven my car a few miles along the freeway with a very low oil pressure. The light never came on but as I rolled up to an intersection I glanced at my pressure gauge it was hovering between 0 and 5 psi. I shut the motor off and coasted into a parking lot. Towed it home. It’s been a few days but I swapped out the filter and oil. Threw a fuel filter on while I was under there. Anyways, cranked it a little bit with the pedal on the floor to try and circulate a little oil and then fired her up. I was relieved she turned over freely and then actually started. Pressure was up there towards 65-70 psi but I’m getting a clanking from the front right and she seems a little rough. I didn’t run her for very long and only once lightly gave a blip to the throttle. My question is if the tensioner collapsed due to not enough oil pressure, would it not come back to life once pressure was reacquired? Should I try and let it pump itself back up or just pull the cover and replace it?
