help me
Erti
Hungary
Hello
2010 Mustang 4.6 3v , from cold idling no problem, when the fan turns on the fuel trim will be high. i get p0171 p0174.
07 Boss
Sin City
That actually means your fuel trim is low and your running lean. The fan coming on should have nothing to do with it. I don't think the codes are caused by an exhaust leak because it's on both sides which means for some reason you're not getting enough fuel.
Dino Dino Bambino
I have a red car
Cyprus
Those are lean codes, and the fuel trim is high as the ECU is trying to correct it.
If this only happens when the fan comes on, the only thing I can think of is the intake pipe isn't properly attached to the throttle body and some of the fan wash is leaking into the intake tract.
Erti
Hungary
192.2F on fan= high fuel trim, 0F-192.2F= correct fuel trim
