How to change rear axle bearings and seals
Deez-67
Edmond, Oklahoma
New axle bearings and seals.
Get the car in the air.
let gear oil drain while you take off the wheels
remove the rear cover, sorry for the bad pic
remove caliper/caliper bracket - 2 bolts on each side
stick caliper in a safe location the isnt pulling on the line
remove the rotor
remove the carrier bolt for the cross pin
hope it doesnt break - this one did, good thing i was able to get the rest out
remove the cross pin
push axles inward and remove the c-clips
remove the axle - dang leaking seal exposed
bearing/seal puller in place- hook up slide hammer and bang away!!
what it looks like once out
new bearing and seal
bearing/seal installer
new bearing and seal in place
slide axles in, insert c-clips and slide cross pin in
new cross pin bolt
install cross pin bolt
Deez-67
Edmond, Oklahoma
put rotor and brakes back on
clean old rtv off rear end and cover
install cover with a nice bead of rtv on it
bolt wheels back on while rtv sets up
i forgot to take pics of putting friction modifier and gear oil in it. but there is a plug on the drivers side front of the diff to fill it at. put the friction modifier in then fill with gear oil til it comes out the fill hole.
set car on the ground and torque the lug nuts.
all done ready to roll!!
94tbird
4R70W FTMFW
NY/NJ
This is an amazing write up sir, Thank you. I am going to move it to the DIY section, where it will be more suited. I will leave a redirect here, so others can find it here as well!
lostsoul
2014 vett or 2015 stang..
Gay Area
bad ass.. thanks.. I wish we had more of these hard core stuff then 20 threads on removing the damn side emblems. haha
Ken04
gm troll basher
Santa Rosa Ca.
great step by step write up. I printed and used this to replace my wheel bearings. Too bad the 1st Ford tech was wrong, it wasn't wheel bearings. But I did get to do this again to replace the pinion bearings. Too bad the 2nd Ford tech was wrong also. By the time I pulled the carrier out to look at the carrier bearings the second time I remembered how to do it. Fortunately I did remember the Ford tech being full of shit after the carrier bearings and races looked perfect.
But this DIY was very helpful and informative. So thanks.
kona302
south texas
Does anyone know what to torque the cross pin bolt to? I put it at around 5-10lbs.. I had it set at 10 but the wrench never clicked but it was firm plus I didnt want to break it.
Otherwise, clean install. It was alot easier than it seemed, replaced a bent axle, the bearing and seal. The hard part was taking off the watts link parts and putting them back in.
