I'll probably wait till I put in the TR6060 too before getting a new shifter.
The 2008 Ford Mustang Shelby Cobra GT500KR revealed! “King of the Road†returns and will offer an estimated 540 horsepower and 510 pound-feet of torque, thanks to revised ignition and throttle calibration and a cold air intake system that replaces the stock unit.
Power is delivered to the rear wheels through a Tremec TR6060 six-speed manual transmission and 3.73:1 rear axle ratio, upgraded from the standard GT500’s 3.31:1. Gear selection is courtesy of an all-new Ford Racing short-throw shifter making its debut on the KR. Topped with a white ball, the new shifter is 25 percent shorter than the unit on the GT500 providing for crisper, sharper shifts.
6 speed...I haven't herd of the TR6060 trans. Is it a higher torque rating? Is it a 5 or 6 speed and is it a direct replacement for the stock trans? Who has it?
Sorry for so many questions.
Can't you lub them?I love my lca's aside from the clunking noise they make. Stupid metal bushings.
They are spherical rod ends (heim joints)... metal on metal.Can't you lub them?
So I take it these can't be lubed. Won't WD-40 work to quiet them down. That will also help keep water from corroding them form the inside.They are spherical rod ends (heim joints)... metal on metal.
I don't know where you heard that but it works as a lub and water idissapating treatment. It works good for loosening bolts also.WD-40 was made to help loosen rust, I would never use it as a lubricant.
CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape, stickers, and excess bonding material.
DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
LUBRICATES: WD-40's lubricating ingredients are widely dispersed and hold firmly to all moving parts.
PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
While its uses are many and varied, WD-40 should not be used as a general-purpose lubricant, as it dries very quickly and collects dust. This can result in serious damage to machinery and equipment designed for use with heavy oils when they are lubricated with lightweight WD-40.
