eighty6gt
- Joined
- May 9, 2011
- Posts
- 4,299
- Reaction score
- 405
How does an engine run for more than an instant when you drive and drive and eventually bend all of the valves!!? Makes no sense to me.
FRPP 3V heads are discontinued.Been a few years but you used to be able to buy FRPP stage 2 heads for about $1K each I believe. Bolt them up and go. Check with Livernois.
I lubed the pistons and cylinders with a copious amount of wd40 before installation. I had thought this was an appropriate lubrication but I'm willing to admit that may be wrong.
Well a new day a new headache. Pulled he motor back out and began disassembly. I pulled the one piston out with the ptv contact so I could polish it out and I'm not to sure about how this cylinder looks. There appears to be a bit of irregular wear on the cylinder and piston. So need some opinions on the cause again. I'd almost rather this be something I did at this point because if this is from the guy not boring and honing the block with a torque plate properly I may actually kill him.
You can just barely catch a nail on some spots. It almost just feels kinda rough if you run your nail real slow over it on both the piston and cylinder. similar marking are on each cylinder. Although some barely visible compared to others.
Let me know what you guys think.
I would say the pistons are fine as long as the block does not need to be bored of coarse. I can't help with that one since I am not there to see it myself. I see you are in NJ, What part? I am about 20 miles south of Trenton. Rod bolts, are they torque to yield bolts? If not then they will be fine. I would plan on replacing the rings.
