sharkbaits
- Joined
- Jan 12, 2012
- Posts
- 606
- Reaction score
- 0
Just a heads up about the new ID1300 injectors.
Shoot me a PM if your interested in a set! I've got a special introductory deal going for a limited time!
The ID1300 is an all new injector, designed in partnership with Bosch Motorsport to fill that void. This collaboration has given us the ability to design a high flow injector with characteristics specific to the needs of the high-performance tuner. The ID1300 is not a modified production injector. It is a clean sheet design, built to our engineering specifications, exclusively for Injector Dynamics.
The ID1300 was designed with alternative fuels in mind, and is the only high performance injector available with all stainless internals. It is compatible with all known fuels, and will stand up to the corrosive nature of alcohol better than any injector on the market.
While the ID1300 was designed with an eye towards ethanol fueled engines, we have accounted for the occasional need to convert back to gasoline. The ID1300 has a minimum fuel mass compatible with gasoline use, and will provide exceptional idle and cruise behavior under these conditions.
In addition to its multi-fuel capabilities, the compact body of the ID1300 allows for fitment in more than 200 applications, making it one of the more versatile injectors in our lineup.
In the next few months these will be made on Bosch's production line.
Retail on these are $1560. But again for a limited time we'll be hosting an introductory pricing special!
http://www.jpcracing.com/injector-dynamics-id1300-fuel-injectors/
