Installing autometer tach with shift light model 6187
Joe88xj
Wernersville, PA
Hey guys quick question for you I bought this tachometer with a shift light on it the smaller one 2 1/16 in is there any way to install this in a 2006 GT and to work properly without spending the extra hundred dollars on auto meters tach signal box?
Thanks in advance!
drive_55_not
Thanks in advance!
Depending on when your car was built,, C-25-B on the 50pin PCM connector is a Clean Tach Output that can be used to drive an external tach,
If your's doesn't have it then you'll need a tach adapter ..
