Issues with v2 system
irishpwr46
Official Site Vandal
NYC
So if I park my car normally, everything is good. But if I drop it when I park, I come back later and the air tank is empty. I'm thinking one of the solenoids is sticking open. What could I do to fix that? Pull the hose and spray some silicone lubricant into the ports?
junkyard08
Indiana
have you check all the fittings on the tank to rule out a leak there? Seems odd the tank only loses pressure when the car is aired out.
Wes06
So fittings at the tank are good. How about the hose entering the block?
The valves going from the tank should only be into the bags and not out the side.
Does it leak down any other time or only when the car is aired out on the ground?
irishpwr46
NYC
parked yesterday afternoon at 4 pm, just checked it out and tank was still at 168 psi. i lowered it down, and now ill go back and check it out in an hour or so
irishpwr46
NYC
Tank is empty and compressor won't come on. Can't figure it out. Battery was dead for a few days, and now I'm getting a buzzing from my shaker subs. If i ground the compressor relay, it comes on. So the v2 isn't sending a ground signal to the relay
irishpwr46
NYC
yeah, i talked to an airlift tech yesterday and he says the v2 is shot, that they will send me a new one under warranty. i just have to call them tomorrow
