Well... The mystery is finally over.
I just did a leak down-test on the motor. Something that I paid a shop to do earlier last year. sigh
Like always, you want something done right, you got to do it yourself.
Anyway, here are the results:
Cylinder 1 - 90 psi = 10%
Cylinder 2 - 97 psi = 3%
Cylinder 3 - 82 psi = +15%
Cylinder 4 - 86 psi = 14%
Cylinder 5 - 98 psi = 2%
Cylinder 6 - 82 psi = +15%
Cylinder 7 - 90 psi = 10%
Cylinder 8 - 96 psi = 4%
(The source pressure was 100 psi.)
Obviously this is pretty bad. But how does a motor in this condition still make +600rwhp!!?? Shouldn't it be down on power?
Just to make sure, this is how I performed the test:
-Set source pressure to 100 psi.
-Set the cam lobes to 11 and 1 0'clock.
-Held the breaker bar to keep the crank for spinning for dear life!!!
-Connected the spark plug supply hose to the leak-down tester, verified 100 psi source settled, and maintained for 7 seconds or so (until reading settled and maintained).
Wow...what a frustrating year!!!
I bought new heads for nothing...although, these heads are better and will provide a little more power. lol
I'll use my current heads to rebuild the stock motor that crapped out for another project car:
So I am guessing this was all due to the worst break-in in history...?
