mrgtx
- Joined
- Aug 1, 2011
- Posts
- 124
- Reaction score
- 2
IIRC, JLT makes a similar catch can for pretty much every S197 version so it seems like this question would be best asked here...
One of the first mods that I did to my 2011 GT was to add the JLT catch can. While they make them for both cylinder banks, I read that the passenger side was the more critical one so that's the one I installed.
Sure enough, it collects oil that would otherwise be lining the intake manifold and the backs of the valves over time. I typically collect a few milliliters every thousand miles...not as much as some other folks report but that could be due to a lack of effectiveness of the catch can as much as a lack of oil getting sucked through. In either case, it seems worthwhile to have the catch can in place.
I have heard complaints that these things can cause vacuum leaks. So far, I hadn't seen any signs that mine was leaking but noticed that the hose clamps (OEM/clasping type) between the hose and the can unit were no longer snug. That certainly could be the start of a problem (if it wasn't already).
It has been on the car for ~24,000 miles so it's possible that the hoses are deteriorating (and collapsing?) but they look fine.
What is the failure mode for these catch cans? How do folks figure out that they have a vacuum leak? Do you always get a CEL?
Any thoughts, insights, opinions are very welcome and appreciated.
-Mike
-Mike
