Just purchased my 1st Mustang
Discussion in 'New User Introductions' started by Octavious, May 15, 2018.
  1. Octavious
    Octavious Junior Member
    May 15, 2018
    Knoxville
    12A0A0FE-A27D-4268-B3BB-8DA3185B774B.jpeg Long story short I’ve been into air cooled cars, Jeeps, and motorcycles. After almost getting hit head on while riding I decided motorcycles might not be good for my health, and wanted a fun daily driver. My kids wanted a convertible. Insert the Mustang...
    I tried to do as much research as I could before going in and searched for 1.5 months before purchasing my first Mustang last weekend.
    Initially I was looking at 05-06s cause they fit my budget better. (I used the money I had from selling my bikes to buy the Mustang) and then I realized the 07+ had side airbags so I tried to find one of those.
    Eventually I found an 08 GT premium convertible with a manual and contacted the seller. It was in Atlanta, about 3 hours from me, but super clean and almost stock. The only mods are mufflers removed, cats still in place, and straight exhaust installed. It came with two small Flow Master mufflers in the trunk. It has 125k miles,and reciepts for a new clutch, new Michelin tires. But other than that no records.
    I’ve been reading on here and now I’m worried about the plugs and not sure how long ago or if they have ever been done. I saw a thread here saying there was a date in late 07 when they corrected the heads but it didn’t say when. Can anyone tell me? Also anyone in Knoxville wanna walk the newb through a plug change?
    And the a/c worked fine all last week, but cut out yesterday, and then came back on a few minutes later. It seems to be working fine now. Thoughts?
    Thanks
  2. 07gts197
    07gts197 forum member
    599
    13
    Feb 5, 2015
    Naples, Fl
    Nice stang man! Yes the 07-09s have the goodies the 05-06s dont have.
    The spark plug issue, if you have early 3v heads, arent a huge issue if the plugs dont have like 100k+ miles on them and you have access to the lisle tool and a lot of patience. There are 2 things to look at, the better heads were rolled out in october of 07 so look for that date sticker, and also check the coil boots they will be brown if theyre the newer style 3v heads.
    The ac issue Ive never heard of so I cant help you there. The only thing I can think of is maybe its low on refrigerant and doesnt work well at idle/low speeds but starts working when moving again.
  3. 46addict
    46addict 13726548
    1,656
    40
    Aug 25, 2016
    Lawrenceville, GA
    The AC will cut out like you're describing when the PCM detects a misfire. But you'll also see a flashing check engine light if you're misfiring. I wonder if there are any pending fault codes on the car.
    And congrats on the purchase.
  4. Octavious
    May 15, 2018
    Knoxville
    Thanks. I had a a/c kit at home and I checked and found the procedure on the online manual about checking and adding refrigerant. I followed the procedure, I found that it was low, and added some. It’s been ok since then so I’m hoping that was all it was.
    I also found a had a burnt out rear turn signal and replaced it. Yeah first fix out of the way.
  5. stkjock
    stkjock ---- Madmin ---- Staff Member
    36,363
    236
    Jul 10, 2007
  6. bujeezus
    bujeezus forum member
    2,515
    28
    Aug 31, 2015
    Alabama
    Welcome to the forum.
Share This Page
