Hey 408, I run the V3's, albeit with big bars. The settings I tend to run out of track is rebound a click stiffer at both ends than the factory recommended, bump 3 clicks off open in the front, and bump one sweep open on the rears.
My guess is that the Saleen spring rates are actually pretty stiff (stiffer than the KW's) because the Racecraft look similar to BC/Megan etc, purely a guess though.
Here's the info I got from KW about a year ago:
"Michael,
The working rates for the V3s on the Mustang GT are 343 lbs/in front and 200 lbs/in rear.
The Clubsport kit holds linear rates which are 571 lbs/in front and 340 lbs/in rear.
If you have any more questions please let me know."
My thinking would be that the V3's will ride better and generate the same handling with lesser spring rates due to improved valving. The V3's are really not a "track" coilover, they're a very nice street coilover that won't fall on their face out there, but I definitely needed to augment their roll stiffness with sizable bars (38mm BMR front, Eibach rear set to full stiff -- > Likely going to BMR or Whiteline rear).
Since I don't autox and do HPDE, the setup is the best of both worlds for me. For the rapid transitions of autocross, you could set the car "loose" as they suggested (rear bar full stiff), and try dialing in more rebound to get the transition you want.
My +1 click on rebound all around was because the recommended settings felt underdamped and jiggly, and the car had sizable front end lift/rear squat under acceleration out on track and brake dive/rear lift during heavy braking zones. The +1 all around made that behavior far more manageable without totally stinting weight transfer onto the tires.
-Mike
