BruceH
BBB Big Bore Boss 322
So I have the iron block like the 03/04 cobra in my car. I was too cheap to get the aluminum block. Is the block I have weaker or is it just a weight thing?
Going off of memory here. It comes from a magazine story I read prior to building my first motor.
The story read that the Terminator used the iron block because an engineer felt it was stronger than the 1L (Mach 1) aluminum block available at the time. They had a 1L block come apart around 1000hp during some extreme testing. The cause of the block failure had to do with something else going wrong but the engineer felt the iron block would of held together regardless.
I know that the stock Terminator motors are one of the strongest complete motors Ford has ever produced. That's mostly due to the Kellogg crank, h-beam rods and Mahle pistons. The blocks aren't know for failure at a certain power level like the Coyote blocks are. People push the stock Terminator motors pretty hard and they stick together.
It's held up so far right? IIRC it's been about 6 years, that's a pretty solid testament to it's strength.
