So, I purchased the input shaft thinking mine was toast. Turns out that after pulling the trans and converter, the input shaft is intact. It looks like the splines on the stator(?) inside the converter are stripped. No biggie as I was having the converter re-stalled and it won't be too much more to have a new part thrown in.
Anyways, my question is how to get the new shaft in. I have read that this shaft needs a little massaging to get in. What exactly is the issue? Is it the actual diameter of the spline area? Seems like the splines match up but it won't go on. If I "polish" the outside edges of the splines down a bit will it go on, or are there other factors involved? I don't want to start working on this piece if that's not going to work because then I can't return it. But if I can persuade it to fit pretty easily I will swap it for the cryo-hardened one that is in there now.
