The Dizzel
comming at cha' with NA
So my pmp/jeggs linelocks have got here , Could anyone direct me to a thread on installing them? and thread for proper bleeding of break system.
thanks all
thanks all
The kit has changed a little to make it compatible with more solenoids but these should get you going.
Yes just be careful not to get any in the brake system. Another option is red Loctite, it is an exceptional thread sealant.Kevin your instructions say to use teflon paste.Couldn't you also use teflon tape?
Some ascii art of mine here and discussion of this in that thread as well:Hey all, i got my solinoids (sp?) installed, but am a bit nervous about my wiring schematic...does any one have or could any one post a wiring diagram of sad installI have all the parts, just a bit unsure how to wire in the switch with the 12 volt relay.
thanks
http://s197forum.com/forum/showpost.php?p=53171&postcount=7
p.s. if you aren't using the cruise control and can't work backwards from that discussion which is, let me know, I can fill in the blanks if needed...
Bleeding the brakes is no biggie - done a couple of times on this car without headaches - just connect the hose into the catch cup, loosen the bleeder until you see fluid come out - pump brakes until its bubble free - tighten bleeder (not too much, it can break) - repeat on other front side brake...hey thanks, i am gona go straight from the battery via inline fuse to the 12v pin on relay, relay grounded to chasis on grnd pin. from fuse panel behind kick plate i will add "fused add a circuit" from that is where i get sorta lost.
My switch has three pins grnd 12v and acc how would i wire that in.?
..I know i am over thinking this... I am just stressing bleeding the brakes...its long and laborus
Or worse yet, you can have happen what happened to me. The bleeder didn't break, but the caliper stripped out, and I had to buy a new caliper.tighten bleeder (not too much, it can break)
but I did not want to drill more holes in the chasis, I post pics when its all done
Good luck - "have fun stormin' the castle"were supposed to race in Sac tomorrow...if nothing goes wrong with my brakes that is....
