New Product Release
Livernois Motorsports “Coyote” Drop-In Spring Upgrade
Contact: Livernois Motorsports
2500 South Gulley Road
Dearborn Heights, MI 48125
Phone: (313) 561-5500
Manufactured exclusively for Livernois Motorsports, these springs are the only true drop-in performance spring for the 5.0L 4-valve engine.
Specifications:
Install Height: 1.575
Max. Valve Spring Lift: .580
Spring Pressure Closed: 70lbs
Spring Pressure Open: 190
Coil Bind: .950
Retail $319.99/set
For more information please visit www.livernoismotorsports.com or call (313) 561-5500.
Dealer inquiries are welcome!
Thank you
Regards,
Rick LeBlanc
- No added cost for special retainers, spring cups, or seals
- No machining necessary
- Designed to work with all factory hardware
- Give added spring pressure needed for most aftermarket camshafts
- Eliminate valve float to reduce the risk of any engine damage in high lift or RPM applications
Specifications:
Coil Bind: .950
Retail $319.99/set
Thank you
Regards,
Rick LeBlanc
