As long as you stayed out of boost/WOT for the trip to/from the inspection facility I am 99% sure you would be ok.
True but you learn to live with the smell and the noise can be toned down depending on the mufflers.
[...] ...he said I don't put enough miles on the car to be concerned ( I drive it about 1000 miles or less a year)...
Actually the only longtubes that I know of where you do need to drop the k-member are the Kooks 1 7/8.
The only LT's that I have read about that does not require the K member being dropped are JBA but I cannot verify as I have never used/installed JBA; other than JBA to the best of my knowledge the K member needs to be dropped to install the LT's.
Non-foulers with the o2's on! Passed for me and I have no cats.
Tell them to turn the rear o2's on and get yourself to vatozone and get two packs of these.
http://www.summitracing.com/parts/rnb-42009?seid=srese1&gclid=CMz8nsOSgLwCFSho7AodGBYAEA
Then do this...
http://forums.evolutionm.net/evo-ho...k-plug-anti-foulers-remove-ses-cel-light.html
Again, passed after a drive cycle with my rear o2's on in the tune and NO CATS.
Thanks for the info bro ! I am not sure what you meant by passing a "drive cycle" I have to pass plug in OBD II testing so as long as it doesnt throw codes, Im ok.
Drive cycle is when your vehicle performs a series of tests to make sure all the emission equipment goes to ready status. If it says not ready you fail....drive cycle is driving at a bunch of different speeds and times etc...I have ford drive cycle here ill forward it.
I failed the first time because I didn't do a drive cycle, the computer says the o2's aren't ready or something, it took me like 30 miles to complete a drive cycle, went back with no other changes and passed.
Good to know ! Thanks.
Do you have something to monitor the drive cycles?
What do I need ?
