antonio1988
Redline: 8600rpm
but you can't use longtubes with turbo's guy...I agree. This would be the best first step. Then if you want more, think the turbo.
I agree. This would be the best first step. Then if you want more, think the supercharger.
x2good choice
i wanna hear from some of u guys after a couple thousand miles with the on3 kit. its a great deal until the turbo seals blow, the center section starts flopping around and the turbo headers crack cause its all cheap chinese junk.
$1800 will always be too good to be true. its that cheap cause its junk. just saying.
Funny you should mention that, the steel is American and American made, it's the turbo, wastegate, and bov that are the Chinese things in the kitUsually it seems with chinese stainlesses is that they are thinner than designated, or that the welds were not shielded front and back and are weak do to porosity or oxidation. Those two are often what lead to cracking, as well as using the wrong filler rod. 300 serious stainless steels actually have a decent coeffecient of thermal expansion, so as the headers heat up, if the wrong filler was used, it can cause welds to crack.
I had a professor who is big here (Texas A&M) in the manufacturing processes etc. He is from China and would show us tons of pictures in class of Chinese welding stuff in shops with loads of improper gear. So wrong fillers, improper shielding, etc has to happen. FWIW, my favorite picture was a Chinese Welder wearing a piece of cardboard with a rubberband holding it to his head, and a cut out for sunglasses as a welding hood.
anyways, just a bit of info. Sorry for the offtopic-ness
Regarding gains from headers.
Has anyone had their car dyno tuned before the header install and then afterwards to show the true benefits with that being the ONLY change?
Without the dyno tune before hand it's not a fair comparison.
