Main and Head studs for EcoBoost 2.3
These LME main studs are made from 8740 chromoly steel and have a 190,000 psi tensile-strength rating.
They are precision centerless-ground and thread-rolled to Mil-S-8879 specs, with a black oxide finish for corrosion resistance. The kits come complete with hardened washers and high-strength hex nuts.
The LME cylinder head studs Are cold-forged to ensure molecular integrity.
They are heat-treated prior to thread rolling and machining and are rated at a whopping 200,000 psi and are made of 8740 material.
These kits come with 12-point nuts, and come complete with hardened parallel washers for an even load distribution and accurate torque readings.
LPP701123 Head Studs
LPP701124 Main Studs
