Hey guys, this might be a long read but I could REALLY use some input, advice and help....
I've spent the last couple days picking my brain and the brain's of others to come up with an answer to a growing concern I have about my most recent dyno results.
If you know my thread about putting Long Tubes on the Coyote motor without a tune, then you know I've been compaing dyno results for a while now. Here is my thread:
http://www.s197forum.com/forum/showthread.php?t=111564
The last numbers I put down were 383 RWHP (SAE Corrected) with just Long Tubes, Catless Mids (X-pipe) and RTR Axel Backs.
Well, since then I've added a Airaid CAI, Boss 302 Intake Manifold and I've gone through several tunes. I've learned about this motor a bit and re-tuned my car using HP Tuners. Car felt pretty decent (except for low end tq loss from Boss IM) and I've had a consistant 4.6-4.8 60-100 Using my tune.
I just went to the dyno (same one I used every other time) to see the fruits of my labor and get a sense of my progress in power....
Well, after 3 pulls I put down 386RWHP. Needless to say I was shocked and extremely sad with a hint of being pissed. Just to be sure, I loaded every tune I purchased and did pulls with each one to compare.... all were lower than my custom tune by about 3-7 RWHP! So the tune was not at fault. AND just to be 100% sure, I loaded the stock tune (I know it's not a good idea with my mods, but I just had to narrow the problem dow) and I did a quick pull.... 351RWHP! When I was bone stock I put down 368RWHP SAE Corrected.
Now, I've been told that it was because of the heat and 70% humidity on Friday here in Massachusetts. It was about 94 degrees in the shop when the pulls were done. It was about 55 degrees and raining on my stock pull and about 65-70 degrees out and way less humidity on my LT's and no tune pull.
So could that much heat cause THAT much of a power loss, or is my car having a serious issue that I need to track down?????
There is no CEL, no running issues, no idle issues, no AFR issues, fuel trims are good but my left bank is a couple % richer than my right bank according to my logs STFT and LTFT readings.
Others and myself are completely stumped. The guy running the dyno said he has never seen an NA car have such a power loss from a previous pull and only see's that on high powered boosted cars - which makes total sense. I have not found anyone who has had similar results like mine with no hint of an issue with the car. It runs great, at least to me. I have nothing to compare to.
So, any ideas on why I've gain nothing from all those mods AND a tune??? Anything else you need to know to help?
Short version: A no tune dyno run was 383RWHP with long tubes, catless mids and rtr axel backs. Added Boss IM, CAI and tuned and only put down 386RWHP. Same dyno.
