Rick@Amazon
- Joined
- Mar 25, 2008
- Posts
- 46
- Reaction score
- 0
We had to modify our JLT intake to make it fit the Nitrous Outlet system. As you can see in the first photo the tubes go right into the solenoids. We moved the tubes for the PCV and auto about 5 inches towards the filter. I ordered some better plugs to replace the ones I used.
After we moved the tubes we put a some fuel/vapor line in between the valve cover and intake to give it some flex.
Everything turned out pretty good and looks clean. Now we will mount the bottles and wire the Nitrous Outlet window switch and glove box switch panel.
We are a distributor for nitrous outlet nos systems. They make an excellent kit for the 5.0 gt. They also have all the supporting parts to go with the kits. If interested give us a call.
