06gtmustang
Having issues footbraking my car with ptc converter and ptc suggested breaking in the converter and making sure my rear brakes have enough holding power. I have stock discs and pads on all 4 corners and running a racecraft 1.032 manual brake cylinder. Before i sent my ptc converter for a restall it only footbraked to about 1900 and started spinning the tires. After a restall and rebuild which they said should get me atleast 500-600 more rpm footbrake its still spinning the tires at 1900 like before. Whats the best way to give me more rear brake bias? With maybe a proportioning valve? Ptc said trying to set my stall higher car will only drive thru the converter in high gear.
