ARMORINE
ok guys i just got done doing a ported head swap on my mustang. mmr stage 3 heads with ground valve guides(that part scares me alittle but ill get to that later)
motors all back together i double checked all of the sensors, all the wiring's hooked up. i pulled the crank sensor and checked the plugs to make sure the pins werent bent. put a test light on the coil wires and checked fuel flow.
i cant find anything wrong. the coils are getting power, she's getting fuel but nothing. not even so much as a pop.
so my only ideas are this.
1. after talking to my tuner he suggested that maybe the plugs arnt firing. my test light only requires 6 volts to light and thats not enough to fire the coil packs. im going to pull a sparkplug and hook a coil pack to it to see if its actually firing(cue me getting the s$%t shocked out of me)
2. crank sensor rings on backwards......i know it isnt. you can only put it on two ways and i put it on with the sensor prongs facing forward. exactly as i pulled it off. but i did test fit other parts and remove it several times.... so i guess could have flipped it on accident. this would cause the ECU to fire the plugs out of time..... if the plugs are firing im going to pull a valve cover and check the timing sensor ring.
any one else have any ideas?
