Pumpkinfish
Johnny Quarter Mile
Long story short I have had a chirp that I tracked down to my alternator. I have a new alternator from Ford and a new Saleen alternator bracket. I also double checked with GI Joe how the Saleen alternator bracket should be shimmed with his 8 rib kit. Everything is setup correctly.
I borrowed the Gates belt laser alignment tool from a friend and found that my alternator has an angular misalignment. When I shoot from the blower to the alternator, the light is off by a half rib. When I shoot back from the alternator to the blower, I am off by half a rib but opposite side, which confirms the angular misalignment. I made the attached diagram to illustrate the laser pointing on the top and the angle on the bottom.
My question is, do I want to shim the amount of a rib or half a rib? Also, with the three legs of the Saleen alternator bracket, do I want to shim the two on the right hand side or just one?
Finally, the Gates tool has an acceptable margin of error. It states for a 6" distance between pulleys half a rib is acceptable,. This distance is 2" to 3" so I am guessing that I have little to no margin of error using their guide.
