Need Help!!!!!
Rod
Hey fellas. I need some very good advice. I just added another mustang to my collection, problem is i have not picked it up. The car is 700 miles away from me and the car is set for 93 octane tune. The car is a 2002 roush stage 2 with built engine running 12 pounds of boost with a procharger and blower cam. The highest octane available around is 91. Should i drive it back with 91 and just add octane booster or what do i do?
mikeysgt
Bakersfield, CA
Might be wrong but I'd say running it back with 91 should be fine if you don't go WOT and just cruise back.
86GT351
Sunny South Florida
Normal driving with the Lower OCtane will not be an issue. If you go into boost that is where issues might start!
Can you buy a couple 5 gallon cans of 110 race fuel and add a couple gallons with every tank of 91 octane gas? My Bullitt has a 93 octane tune and it runs like crap on any brand of premium fuel except BP. A couple times after getting bad gas I would go add a couple gallons of race fuel and it ran much better.
I would also get it retuned as soon as possible. Be sure you get the handheld tuner with the car (if that's how the tune was loaded).
If it comes with a tuner you could pull some global timing.
Rod
Damn. Its gonna suck staying out of boost. But if there is no other way. What about octane booster?
I know nothing about messing with the tuner. I leave that up to the pros.
D98GT
STREETCAR
Liberty TX
Stay out of the boost until you get it home. Octane booster from an autoparts store isn't going to get you where you need to be.
Even after getting it home, I would put it on the dyno to check the A/F and tune according to what octane you can constantly run.
Find out who tuned it, get an update for 91, install, drive and enjoy
All you would have to do is load the tune, when adjust options comes up go to global timing and pull -2 degrees. Finish by loading the tune. All it's going to give you is a little insurance. It's not like you are changing the whole tune around, just limiting the spark advance another 2 degrees throughout the rpm range. It's a parameter that is included as an option for just the kind of scenario you describe.
Rod
Im having second thoughts. I think im just gonna get the car shipped to my location. 12 pounds of boost is kind of high to be messing around with the wrong octane.
weather man
Persistance Is A Bitch
MN
Buy a 6 pack (case) of 1 quart Torco, problem solved! Basically, 1 quart per tank of fuel. Good luck!
Rod
It was tuned at a performance shop in California. Im in Texas and so is the car. I dont think ill be able to do that although i wish i could.
weather man
MN
Where do they sell this stuff ?
Amazon or: http://torcoracefuel.net/dealers.html#TX
CityNameAddressPhoneWebsiteAddison21st Century Muscle Cars15610 Midway Rd., 75001972 417-7177www.21stcenturymusclecars.comConroeRiley's Performance and Automotive15444 FM 3083, 77302936-231-4256DallasMotorsports Sales 13518 Floyd Circle, 75243972-644-2533El PasoEdge Kawasaki10310 Montana Avenue, 79925915-593-1024El Paso103 Motorsports117 Midnight Sun Dr., 79927915 549-0953www.103motorsports.comGrangerTowers Racing Products 100 East Ash St., 76530512-859-1320 TowersRacing.comHoustonFastlane LLC10541 F.M. 1960 W., 77070713-600-8600HoustonMotorcycles Unlimited 1964 FM 1960 W., 77090281-444-0545HoustonProAm Auto Accessories6125 Richmond Ave. 770571-800-847-5712HoustonTexas Motorsports13207 Allysum Ct., 77429713 819-0134www.txmotorsportshouston.comLewisvilleHPP Racing1671 Riverview, Suite 208, 75056972-394-8208Marble FallsKawasaki-Suzuki of Marble Falls2803 Hwy 281 North, 78654830 693-5044www.kawasakiofmarblefalls.comSeminoleHerman's Performance ShopCR 300 J #510 ,79360432 425-7556 SeminoleSeminole Automotive1307 N Main Street, 79360432-758-9388
Seer
Torch or race gas. This is a simple solution.
