darrens07gt
I have an appointment for a dynotune at Brenspeed in less then two weeks so I need to have this problem diagnosed and fixed before then. I installed a nitrous outlet plate kit on my 2007 mustang gt. It is jetted for a 100 shot and has a bottle heater, purge and NOS window switch. The bottle heater worked great and built up good pressure. The purge worked good as well. But when I went WOT the nitrous just didn't seem to hit.
I'm thinking the problem is likely my NOS window switch. I bought it because it acts as both a window switch and WOT switch so there would be no need for a microswitch behind the gas pedal. I wired it all up per the diagram found in the owners manual found here:
http://documents.holley.com/199r10482rev4.pdf
I set the on RPM to 3000 and the off RPM to 6400. But when it comes to the TPS settings I had no idea what to program it at. I'm lost with the whole rising throttle and falling throttle stuff. Now I bought the window switch used from a member here so he had the TPS mode set up for whatever car he was running. I just left his values in it hoping he had a 4.6 like mine and that his settings would work for me. Perhaps they don't.
Does anyone have experience setting with the NOS TPS setup on a 4.6 3V engine? I bought a voltmeter but I'm not sure exactly where the TPS is to do the test. Any help would be greatly appreciated.
