New best 1/4 mile ET 11.347 @ 120.43
psfracer
billy badass
Valencia, CA
Went to FAMOSO and it was hot hot hot. Easily over 100 degrees at 5 pm. It started cooling down by 8pm and at 10pm I ran this:
11.347 @ 120.43 mph 1/4 mile
7.254 @ 95.89 mph 1/8th mile
I had just a little trouble with the 60' with a 1.673
Then I got back in line and backed it up with a 11.406 @ 119.60 mph.
Here is the video: Click here to see Video
Here is a interesting note: the very first pass of the day, I forgot to load in the race tune--so I ran the 1/4 mile with the pump gas tune and ran a 12.28. My 60' was off also with a 1.82. Point is, when I made the 11.34 pass, all I did different was load in Adams race tune. If you remove the difference in the 60' time (because I spun), you still are looking at a 7 tenth of a second difference between the pump gas tune and race tune.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Way to Paul! Congrats!! :beer:
I'm sure the heat and bad air also hurt the first run.
silverpoison
SoCal
great numbers paul!!!:thumb:
I am sure you can run a 11 flat with a fresh set of tires 15 degrees colder.
psfracer
billy badass
Valencia, CA
Yeah, I think it definitely has a 11.1X in it. The PI converter made a huge difference.
don_w
San Diego, CA
FWIW, I just checked Weather Underground, and it was about 102 degrees at 5PM (DA ~3,850). At 8pm it was about 91 (DA ~3,000), and at 10pm it was 82 (DA ~2,400). It may have been hot, but at least it was dry (19% humidity at 10pm).
psfracer
billy badass
Valencia, CA
That makes sense, so the race tune had a 9 degree and 600 foot DA advantage as well.
psfracer
billy badass
Valencia, CA
again....super run! good to see the money for the converter was well worth it.
Yep, definitely an improvement, and the converter stays locked on the big end to. 3 disc definitely the way to go if you have a power adder.
Mick Mach
Front Royal, Va.
Paul...I have TCI's 3500 stall. Im not sure its a 3 disc or not but its designed for the FI cars. I paid a grand for it sure hope it work as good as yours...couple guys here run one and love them :) havent had a chance to get to the track :(
don_w
San Diego, CA
A while back I was debating between the TCI and PI, but after a few TCI's failed, I've decided on the PI. I haven't heard about anyone having any issues with those.
