BMR Tech 2
Kelly's Replacement Lackey
Higher bar rates can be murder on poly bushings, especially when you're pushing your car hard. When using some of the stiffer 35mm bar settings, we've seen customers split and mangle their poly sway bar bushings. These new delrin bushings will pretty much eliminate bar deflection (leading to more consistent bar and less "parasitic loss") and prevent customers from blowing out their poly bushings. This upgrade when paired with our billet saddles will help serious corner carvers keep their front bars working as they should.
