Jeremy@AirLift
We have taken our already versatile suspension and made it even better! Introducing the Air Lift Performance Track-Pack air suspension. We have developed a coil over style strut and shock to take handling to the next level!! These new mono-tube suspension components are 30 damping adjustable front and rear to help you fine tune the ride and handling characteristics. Front struts come with red anodized camber plates with high quality mono-ball bearings to help dial in your track alignment with over 3 degrees of camber adjustment. Adjustable lower perches allow ride height to be changed independently of pressure, so you can dial-in your preferred pressure/ride height combination.
This front kit goes about 1/2" lower than our existing kit, giving you the ultimate ground hugging stance you are looking for when you are trying to set yourself apart from the crowd. The front offers a 4.75" drop from stock while the rear offers 4.17" worth of slamification. Our suspension will also allow you to go an inch above stock, so steep driveways are no longer an issue.
http://www.airliftperformance.com/applications/domestics/ford-mustang-performance-suspension/
http://www.airliftperformance.com/2012/09/20/carvin-corners/
Front
Rear
Front
Rear
