new pb @ MIR 22NOV14, N/A 3V doing work
lindertw
NoVA
22NOV14 rental @ MIR
2005 mustang gt
21,xxx miles, K&N CAI, steeda udp's, frpp shorty headers, stock h-pipe and cats, frpp GTA mufflers, 5spd manual (stock trans/clutch/shifter)
93 street tune - Woodbine Motorsports
302 rwhp / 317 rwtq
strange single adjustable front struts, gt500 strut mounts, cobra jet front springs (m-5300-q), front sway bar and bracket removed, UPR radiator support, stock 2pc drive shaft, front/rear drive shaft safety loops
metco UCA/UCA mount/LCA's, pinion angle set to -2 deg, strange single adjustable rear shocks, cobra jet rear springs (m-5300-q), frpp bump stop kit, comp engineering adjustable panhard bar, comp engineering pandhard bar brace, BMR relocation brackets, frpp 4.10 gears, LPW diff cover, eaton truetrac diff, removed passenger seat and rear seat back/bottom, short accessory belt bypassing power steering pump, insulating wrap on cold air intake tube
15x4 Weld RTS with M/T ET fronts
15x8 Weld RTS with M/T ET street bias ply rears
3490 lbs race weight with driver, helmet, 1/4 tank of gas, gutted trunk, pass seat and rear seat back/bottom removed (3265 lbs w/o driver and helmet)
12.095 @ 111.08, 1.576 60'
DA was -1895 ft per drag times da calculator for the first run, and it warmed up for subsequent runs.
I'm stoked about the 60' times, and I think there's a tiny bit more in it. I'm confident I'll hit 11's next year, I've got all winter to plan my attack.
rcm90
Alamogordo, Nm
I hate you and your negative da soooo much. Lol
Great times and awesome 60' man! Any mods planned after you get in the 11's?
lindertw
NoVA
I know right? The DA here is unreal!
I like being this close with a stock long block TB to oil pan, and cats in place. I suspect I'll leave the engine as-is and see where I can shave a bit more weight and maybe have a race tune done, and then just have fun with it. It's nice to drive to the track, adjust tire pressure, run the piss out of it and then drive home.
09gt3v
St. Louis Missouri
Where are you located man! Congrats... I make a lot more power n/a and I've only got 12.2 at 112 out of mine with a 1.6 short time crazy numbers for your setup lol
lindertw
NoVA
i just ran mine today and our time slips are about exactly the same. except I'm using 100 shot of nitrous Fml
you'll get it dialed in
it was at Maryland International Raceway - home of mineshaft air and great hook. We're spoiled out this way :)
fdjizm
Drag Queen
NY/NJ
You bastard, man i want to go to the track right now.
STOP IT, put the car away you're done.
torchred
Well if it makes you feel any better I have your exact setup and same tuner and im still working on 12s lol. I still have stock tires tho
lindertw
NoVA
my setup info is here; post up a thread in the drag forum and folks will chime in to help you knock your times down (disclaimer - if your track is at high altitude there might not be any help for you)
DVEST8R
good job. I love seing results from your and fdjizms cars
lindertw
NoVA
Make the battle royale with Fdjizm happen!
interesting, I plugged fdjizm's best run with my best run into the time slip simulator link Now I don't really try at all for r/t during test & tune so whatever is on my slip is usually a fluke if it's good. Plugging in our numbers as-is on the slip the simulator (heads up) says I come out with the win by 8 feet. Zeroing out the reaction times and going heads up fdjizm gets the win by 17 feet (at least as far as the simulator app is concerned :clap:
thanks man - I enjoy the hell out of your updates too, you've got that car moving out!
fdjizm
Drag Queen
NY/NJ
It would be a fun race you'd definitely get me off the jump with those stupid 60's.
torchred
I run at same track as 09gt3v, saint louis, I think altitude is like 800 feet, and I believe track is closed for year, but ill give it a shot next year and maybe take some hints from your suspension setup over the winter. Thanks
lindertw
NoVA
what size rear tire man?
m/t et street p/n 3752... 26x10.5-15 (26.1" diameter), 4.10 gears
Awesome times man!
thanks!
cool, have fun wrenching this winter!
