Steve@UPR
- Joined
- May 14, 2015
- Posts
- 6
- Reaction score
- 0
** NEW FROM UPR PRODUCTS **
The UPR Billet IRS Vertical Link for your 2015-2016 Mustang S550 2.3 V6 or GT.
These are made from 2024 Billet Aluminum and feature Delrin bushings & Stainless Steel sleeves to replace the factory stamped steel links with rubber bushings. These new links will limit deflection under load which will reduce wheel hop, allow for harder launches and more consistency in the suspension.
We wanted to put ours ahead of the rest with using 2024 Billet Aluminum instead of the standard 6061 that our competitors use because it adds strength to a critical part of the suspension. 2024 has a tensile strength of 68k psi compared to 45k psi or 51% stronger than 6061.
» Delrin Bushings
» 45-60 Minute Installation
» CNC 2014 Billet Aluminum
» Reduces deflection & wheel hop
» Stainless Steel Sleeves & Washers
Only $159.99
Order yours over the phone at 561-588-6630 or online at .
http://www.uprproducts.com/mustang-pro-series-billet-vertic…
» Delrin Bushings
Only $159.99
