New stance on FRPP K springs
droptopstang
Naples, FL
After receiving the wrong springs at first and sending them back for the right ones, I was finally able to install them over the weekend and man what difference. Looks a million times better and handles great, I really love these springs. And I was able to re-use my strut mounts with no issues which was also a plus.
Pic of the new spring installed after I cleaned up and re-painted the stock strut.
And a pic of the finished product, sits absolutely perfect IMO.
droptopstang
Naples, FL
Looks good, how's the ride?
Rides really nice. Pitch and roll were really decreased, and it tightened up the handling a lot without being overly stiff. I had FRPP springs on my 98 cobra I used to have and that's what made me choose the same brand for this car. Perfect balance of daily drive-ability, looks and tight handling IMO.
Only negative is that I'm getting a pretty noticeable squeak from the rear suspension now so I have to try and track that down cause it really bugs me.
RedCandyApple2008
CO
I currently have that squeak and rattling in my rear driver side suspension, you should really let me know what it might be if you find out what it is pls. I heard rear upper and lower control arms fix this issue but not sure...I hope so, My stang suspension all stock still.
droptopstang
Naples, FL
I'm pretty sure its the control arm bushings making all the noise, and lowering makes that even worse. Its horrible at low speeds. Control arms will be the next thing I throw on it.
rogcat1
Las Cruces New Mexico
Also have FRPP springs and struts on my 2007. Installed them about two years ago. They have settled probably about another 1/2 inch.
droptopstang
Naples, FL
That looks really good. I won't mind a bit extra drop if mine do end up settling more than they are now. Although I think the drop now with my 20" wheels is absolutely perfect.
Pardue
Lula, GA
I'm on K springs with 20" wheels as well. I wish it was a tad lower honestly.
TGR96
el blanco nino
Huntsville, AL
Just do like Darren did with his RR GT and cut a coil out of the springs!
(I really can't say anything, since I have actually done that before myself) :crazy:
Seriously though, car looks good, Chris!:highfive:
Pardue
Lula, GA
Thanks Chip. I have considered that honestly. I'll probably just buy different springs before I cut these.
droptopstang
Naples, FL
That's what I would do if you wanted to go lower. Then you can sell the k springs on here, I'm sure they would go pretty quickly. I think your car looks great though!
Pardue
Lula, GA
Thanks man. I really would like the rear to be a bit lower but I will most likely keep these springs. They look nice and I don't scrape on everything.
cam101
Looks good. I also have the same springs on my car.
