I plan to assemble and install a new engine. I have the following already:
JDM 302 stroker short block
Ported big valve heads (stage 3 i guess) with heavy duty springs
Timing set (phasers, chains, tensioners, guides etc.)
Head changing gasket/bolt kit
IW 10% OD balancer & ARP bolt
8 bolt SFI flexplate
Detroit Rockers for supercharged engine with lube & new phaser bolts
New high flow water pump
need these:
oil pump with TSS billet gears
remainder of the gaskets
hardened input shaft for trans
bigger fuel injectors (maybe bosch ev14 105lph for e85)
Want:
torque convertor
1 pc drive shaft
maybe bigger cams (127550?)
FRPP throttle body
Who knows though, the 2015 might blow me away and then it's all for for sale and back to stock!
