oil cooler question
dangerzone
sparkplug
decatur ,ms
Sup guys, some may know that im doing a gt500 swap into my fox coupe. I have problem with the oil cooler assembly. I had to use convention (99-04) motor mounts which bolt to one of the hole that bolt the oil cooler up. So, i had to take the assembly off. On that assembly is where the alternater bolts to so i have to find a alternative route. Where can i find a relocation oil filter kit? This is really going to be a set back as there is no good way to do it. Ill take some pics so you all will have a better idea of what im talking about.
