TheKurgan
K&N breather on each cover. Done.
That's what I do too. The breathers just get oily and need to be cleaned every few weeks. No biggie.
The 3v is designed to draw air in from the passenger side and vent through the drivers side. Setting it up like this kept a good vacuum on the motor.
I haven't had to clean my driver side vent since I added them. The passenger side gets a little oily, but there isn't a "mist" or any pooled oil. Clean it every couple months.
Maybe Im lucky (for once) LOL.
The thing about a Procharger is that it's a blow through system. Very different than a pd blower.
You have a few options. I ran my D1 with a breather on a hose for the passenger side and the drivers side hooked into the pcv system. The 3v is designed to draw air in from the passenger side and vent through the drivers side. Setting it up like this kept a good vacuum on the motor. It also allows for unmetered air (a no no) to come into the intake via the crankcase. The small amount of unmetered air coming in through the pcv never caused any problems. My guess is that the amount of air is very small when compared to what freely comes in through the tb.
I also ran my Paxton like this after it was converted to blow through. I'm one of those people who doesn't like crankcase odors, smelled enough of that stuff to last an entire lifetime back in the day.
I know of others who run their blow through setups like I ran mine. Nobody has ever had issues with it. A search of this site will turn up a whole lot of opinions on how to deal with venting the crankcase. In any case run a catch can and like Brian mentioned it's only needed on the driver side with a 3v. This is because of the airflow path. In through the passenger side and out the drivers side.
If you run breathers then oil mist will get pushed out of both sides because of the lack of vacuum on the drivers side.
Fantastic, this was the info I was looking for. My searching abilities suck because I couldn't find what I was searching.
In any case, this is the route I will most likely take. I don't want a messy or stinky engine bay. So breather on the passanger side and then the the driver side to a catch can or 2, and then to the CAI before the head unit.
