Oil viscosity: 5w20 vs. 5w30
MrClean
Marc; but I go by MrClean
Friendswood, TX
So in warmer climates, like the Houston area, wouldn't it be a worthwhile trade-off to give up a little mpg to protect the engine to a greater extent by using 5w30 instead of 5w20?
I'm running Royal Purple, BTW. and will be switching to RP tranny fluid and rear diff fluid as well (it comes with the friction adder already).
Your thoughts?
MikeVistaBlue06
Inventor: Asshole Points
Richardson TX
Most 5W-30 oils will shear down into a 5W-20 anyway. These oils also have newer additives to prevent wear and such.
The tolerences are tight on these modular engines, so I'm up here in Dallas using 5W-20 year round and no problems thus far. In fact, I have 5 cases of 10W30 oil for my truck that will probably take me years to use! My new Lincoln MKZ, the 'Stang, and the old lady's Honda all use 5W-20!
Here is a good oil site for everything you want to know about oil, but were afraid to ask!
www.bobistheoilguy.com
Thx,
Mike
Hawgman
THE fucking bad guy
Texas
Hell, just move up to Dallas and don't worry about the heat. It was snowing a couple of hours ago.
Larry_H
Custom Motors Built
The thicker oil does play tricks on the VVT and Overhead cams need lots of oil....volume...not pressure
thump_rrr
Montreal Qc,
Your thoughts?
I would not replace the transmission fluid with anything other than what tremec recommends. Mercon/Dexron III
MikeVistaBlue06
Richardson TX
No shit Doc! I told the old lady it was snowing yesterday and she looked at me as if I were on crack or something and mumbled something like it ain't cold enough to snow.
Good to know I wasn't seeing things!!!! :D Thought I might have to give up the booze! :beer:
Mike
MikeVistaBlue06
Richardson TX
Your thoughts?
+100000000000
You're asking for it when you mess with something other than the OEM transmission fluid. I learned this the hard way on a Chrysler!!!
Mike
94tbird
4R70W FTMFW
NY/NJ
snow in dallas huh? damn i figured you guys would be too far south to see that
MrClean
Friendswood, TX
Thank you gentlemen, I'll heed your advice: OEM fluids in tranny & rear diff, and 5w20 in the engine.
thump_rrr; good to see you here!
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Hmmmm... on my "non-stock" shortblock, I've been running 15w-40 dino oil, and now 20w-50 Lucas Oil synthetic. Adam built the motor, and recommended the heavier weight. I've noticed zero issues, and I've been running it like that for over 10,000 miles and almost 400 passes at the track.
MrClean
Friendswood, TX
Cali HP Addict said:
I have been running Royal Purple Synchromax in my 5sp for 4000 miles w/no issues.
Thanks for the input; notice any change? Did the shifteing get smoother? hp increase due to lower friction?
Cali HP Addict
Nor Cal
The shifting defenately seemed to improve. I wouldn't have been able to feel a couple hp since I was over 400rwhp when I swapped.
MikeVistaBlue06
Richardson TX
Changing fluids in the manual transmission or rear-end probably won't hurt.
I was cautioning folks on changing fluids on an automatic transmission! Clutch plates and such in those are picky about the fluid!
Mike
Larry_H
Custom Motors Built
Don, Have you had it on a dyno with 5w-20 and with the 15w-40? I wonder what the difference in viscosity is doing as far as changing the cam timing curve, if any change at all....
94tbird
4R70W FTMFW
NY/NJ
now thats an excellent question!
don_w
San Diego, CA
It's never had 5w-20 in it all. Adam used the heavier oil from day 1.
MrClean
Friendswood, TX
Hmmmm, this couls turn out to be a good thread...maybe we can coax a stillstock S197 owner to dyno it with the regular dino oil just before his oil change, and then dyno it again immediately after the oil change to RP 5W30...preferably on the same day to limit the environmental effects....
