On3 turbo wastegate help!!!
Bryant Newman
Ohio
As the title reads, I have been slowly working on finishing an on3 turbo kit on my 4.6 3v. The current problem (and last thing preventing this from being done) is that the wastegate connections seem to be wildly too far apart. Like, I cannot connect both sides of the wastegate. I have adjusted the pipes as much as possible and it’s still 1/2 inch away from being able to comfortably connect both sides.
Iceman62
Bullitt 6005
NE
Welcome & pictures of your problem(s) are your friend. Get your Smartphone in there & upload some shots. :D
MrBhp
They never fit perfectly. Seldom fit good. You have to keep everything else loose. Tighten the waste gate first. Then everything else.
