KrisR
So my current basic setup is a forged 8.5:1 CR shortblock, Vortech T-trim with FMIC, stock 3650 trans (upgraded clutch) and rear with 3.55s. 60lb injectors, GT500 pumps, longtubes. At 14lbs of peak boost (at 6700rpm) currently with stock crank pulley and 2.95 blower pulley. Stock cams, heads, TB, etc.
For around the same price, I can go with 4.10 gears or a 10% OD Innovators West crank pulley. I'm guessing that the OD crank will bring peak boost to around 17lbs and add around 30-40 rwhp (at around 515rwhp currently). Getting an 8-rib crank pulley will also make it easier to convert to 8-rib if I want to turn it up some more later.
I'm guessing the gears will increase the car's fun factor quite a bit though. I used to go to the track quite a bit, but the car is basically a fun street car now that might see the track a couple times a season. I should add that the car sees up to 400 freeway miles per week as a driver, not that the gears will raise the freeway RPM that much.
Sorry for the brainstorming, but does anybody have any suggestions?
