Similar to a recent post, I am having an issue with the cooling system. Symptoms would be that after about 30 minutes of driving , the temp gauge starts to wiggle a little and then slowly make its way to the hot side. Sometimes it starts to move to the hot side, and I slow down some and get back to around 1.6-1.8K Rpm and it goes back to normal. Cruising at 55 mph on cruise control for 30 minutes resulted in no rise in temp at all. This problem just came up after procharging my car, and I switched in a friends stock h pipe from the same year. Spoke to a friend of mine and he suggested that maybe the cats were bad causing the exhaust to clog up and back up , creating loads of extra heat in the engine. Sorta makes sense with the symptoms , but I want to hear some more opinions. What do you guys think? Can answer more questions if need be so feel free to ask. I go to the dyno on friday so just trying to figure this out before then. Thanks guys
