PA Deep Trans Pan for 5R55
gus
SOLD
Performance Automatic deep Aluminum Pan for 5r55 Automatic Transmission, with tube and locking dip stick. New never installed, have other plans for the car. Fits 2005-2010 Ford Mustang and others. No longer available new. $175.
I have the same on on my 2010 auto + M90 blower. Superb setup. The locking dipstick has a big enough opening to easily add ATF, with a funnel. Locking dipstick comes up beside firewall, on pass side. Those longitudinal ribs on the bottom are 3/8" x 3/8". The lip around the circumference is a whopping 5/8" thick. I would suggest buying a new Ford gasket when replacing the pan. Alum Pan weighs 10.2 lbs. Oem steel pan weighs 3.4 lbs. Being able to use a simple dipstick is a godsend, vs the fubar oem pan. The alum pan is exactly 2.1" deeper vs oem..and holds an extra 4 qts of ATF. I swapped to 100% synthetic ATF. Also comes with a HD magnetic, gasketed drain plug.
Dunno why PA stopped making it. PA still makes the bigger pan (extra 3 qts)..for the 11+ 6r80 auto trannies.
Sammy70
For the life of me I don’t see how/where to email or private message someone?
Can anyone clue me in?
thanks
you can't PM yet, you're too new
I PM'd the guy to check the thread
gus
Yes. I still have this pan and dipstick. New, never installed.
eighty6gt
He'll take your money and buy gold dust to pour into that 5R
Lots of magnum XL's kicking around used for great prices.
Thanks Gus for the same day shipping.
See my post #2. Buy a new gasket for it. I would also install the JDM engineering catch can at the same time, and also use 100% synthetic. Without the catch can, atf will puke all over the road. In my case, I also added a B+M auto tranny cooler, in series with the oem cooler. Without out it, temps would rise from 170 to 200 F in mere seconds, blower on. Now it rises only to 171 or 172 F.
