01yellerCobra
I got a call yesterday from the wife saying her car died. Thankfully she was only a couple miles from the house. When I got there she told me she was making a turn and the car started making noise and the CEL came on. So she shut it down coasted to the side and called me. I had her fire it up and it sounded like valve train. After we got off work I had it towed home and checked for codes. It popped a P0345, bank 2 cam sensor. I thought ok, sensor is bad causing the phaser to hit it's limits. I replaced the sensor with no change. Today I was able to get into it a little deeper. Pulled all the plugs and aside from being wore out they all looked good. We removed the valve covers and everything was in it's place. Nothing looked scored. I wiggled all the followers and they were tight. There was oil pooled in the head so I'm guessing it's getting oil. Just to be sure I picked up a mechanical oil pressure gauge and it showed 75psi at start up. I checked down at the filter where the stock sending unit is. I put new plugs in just because I didn't want to do all the work and put old plugs back in. I tried to datalog it, but couldn't find the right PID for the cam angle. I found cam_angle(0) and cam_angle(1) I think it was. Neither were the right ones because it showed no changed when the engine was idling. While looking up the code it said the crank position sensor could be at fault as well, but I don't see that causing the issue. I'm leaning towards the phaser because if I let it idle long enough the tapping/knocking will get quieter and then the code pops up. The sound really sounds like it's coming from the center of the engine. I didn't think to do the stethoscope trick until I came inside and I was in the shower.
We did all the timing components about 10k miles ago. We did the phasers, chains, guides, and tensioners. The chains still seemed tight to me. Is it possible the phaser is just shot and causing the issues? I read the symptoms for the code and it's dead on. It runs rough, has no power, and shakes a lot. What do you guys think?
